- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
June 2014
June 2014
Hi,,
I have the following problem with my Xperia L (2105). The screen stays on during Viber calls. It's as if the proximity sensor does not work, but it works just fine during regular calls and facebook calls. The only way to turn the screen off is with the power button. Is there a know fix for this issue?.
Thank You...
Solved! Go to Solution.
1 ACCEPTED SOLUTION
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
June 2014
2 REPLIES 2
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
June 2014
June 2014
No it depends on viber. They must update viber to support the proximity sensor to turn off display automatically.
Like in regular calls and Facebook calls, they use the proximity sensor, so when you bring it up to your ears, the proximity sensor detects it and turns off the screen. Whereas in viber, it does not use the sensor i guess.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
June 2014
