- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
STR-DN 1060 and SRS-X77 multiroom problem using songpal
Just picked up a STR-DN1060 since it's supported by Sony's multiroom feature together with the SRS-X77 using the SongPal app.
When i play Spotify connect on the SRS-X77 alone via andriod everything works just fine, I can change sound settings etc. That's also the case with the STR-DN1060, Spotify connect works like a charm, I can chose wich speakers to use /I have a 5.1 system connected to it) and the subwoofer works fine!
The problem starts when i link them together with the SongPal app, creating a group with the STR-DN1060 and the SRS-X77. When I start spotify my subwoofer wont get any signal from the STR-DN1060, and I cannot change any settings on the reciever either, it says: NO.USE when i try to change the speakers or almost anything.
Please help me, im going crazy here!! =((((
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Me three! Was hoping you had found the solution! 😞
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hello! I have exactly the same problem, and by the way no one, not Sony, know how to solve it. I am very disappointed. If anyone here knows how to solve the problem, please help me. Thank you.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi guys
Any news here?
I have the STR-DN1060 and 2 times SRS-x77.
Really hating having to not use these to the intensed purpose...
br Ole
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Comfirmed from Sony support in Norway, STR-DN1060 not intended to (or able to) play on the subwoofer while connected in a group...
Shame it took 2 months to confirm. Problems solved with a Chromecast Audio device in 10 minutes. Groups perfetcty with my SRS-X77 units now.
Hopefully this will be resolved with a FW update later.
