- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Sony DAVTZ140 5.1ch DVD Home Cinema System
Please can anybody tell me if there is a limited amount of Gbytes that can be played via a pen drive via USB on this system as large file sizes seem to stop playing before the end!!
Thanks
![](/skins/images/8F5409FB983461670F0A358BFAFFAC26/responsive_peak/images/icon_anonymous_message.png)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
Looking at the specifications of the DVD system, the system supports USB devices in FAT12, 16 and 32.
Assuming your using FAT32 (as its the most likely):
"The maximum possible size for a file on a FAT32 volume is 4 GiB minus 1 byte or 4,294,967,295 (232 − 1) bytes. This limit is a consequence of the file length entry in the directory table and would also affect huge FAT16 partitions with a sufficient sector size.[1] Video applications, DVD images, large databases, and some other software easily exceed this limit."
More information:
https://en.wikipedia.org/wiki/File_Allocation_Table#FAT32
If this is not your issue, I need alot more information (ie video/audio codec used)
Cheers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi yes everything that you have said is true but this is the formatting of thestick in FAT32, I need to know what the home cinema system will play maximum as it seems to stop playing at anything around 1.7GB !!!
Thanks for the reply my friend but I think this is not my answer to my problem.
cheers once again.
