- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Friday 23rd May approx 19:00 attempted to turn on DVD recorder RDR-HXD995. Seemed reluctant to power on from remote (and when pressing power on on unit itself) as in UPDATE mode. Finally after switching power off at the wall a few times, managed to get it to respond. However when a channel is selected, it displays for a short while and then the screen goes blank. Also, a programme which was set to record, has not recorded.
Is anyone else experiencing this problem - is this July all over again or is it just me?
Any help/advise would be appreciated.
Thanks
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I appear to be Crystal Palace and my machine is now working ok.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Crystal Palace it is.
Just so that you all know, Sony is aware of the issues that you guys are reporting. But please continue to do so, as then they know how many (and what areas) are effected.
Cheers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
crystal palace here too. i see a link developing.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
A parallel thread going on in AV Forums also mentions Crystal Palace a couple of times in the most recent posts.
Good to know Sony are listening to this.
Thanks for the feedback.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have the problem again this evening too and am also Crystal Palace and RDR-HXD870.
Thanks for the France tip, off to try a trip French trip now...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Is the latest problem dated 30th May. I know it happened on 23rd May but it appears to have happened again
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi keithrazzell
There is a problem with some RDR recorders at this moment. The issue appears to be isolated to the Crystal Palace transmitter at this moment. Sony is aware of the issue and is investigating with urgency in order to resolve the problem. In the meantime have you tried the workarounds at the begining of this thread?
Cheers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
We also have this issue happened again tonight (Friday 30th). It seemed resolved last weekend and now again this evening the recorder picture disappears after a few seconds.
Thought i would try a manual update but now it just says "UPDATE" indefinately (unless of course the UPDATE usually takes a long while - 1 hour?).
Getting a little fed up with this Sony!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Sent from my iPad
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I dont think you can turn off the EPG updates. Freeview devices (especially recorders) rely on an updated EPG.
All I can suggest at the moment, is to use the temp workarounds at the begining of this thread.
____________________________
Issue 1 - Stuck Update
Press and hold the On/Off button until the RDR recorder turns off, then quickly press the button again briefly, before the unit tries to go back into update mode.
Issue 2 - No Freeview Channels (ie Blank)
Go into the Tuner Setup and Replace Channels. When asked about which Country, select "France" and continue on with the re-tune.
