BDV-N590 wireless issues
klab90
The built-in wireless feature for my system is no longer working.When I try to use the wireless set-up it goes to the please wait screen then freezes for about 20 secs then it says a usb wireless lan adaoter is not connected. It seems as the built in wireless card might be corrupted in some way.
I have had the system for a couple years now, the first year I used the wireless connection and the second year I used it wired. I have just moved home and I need to go back to using the wireless network connection but it seems sometime during the second year something broke within the system as I know it used to work.
Just wondering if anyone else has had these issues before? Or has any idea how to fix it?
Tags (3)
1 REPLY 1
Anonymous
Not applicable
Hi there
Have you changed routers since you last had it on wireless?
Try the following:
  • As a test move the router and player closer together?
  • Turn off other electrical devices near by, to rule out interferrence
  • Ensure you have the latest firmware installed.  See HERE
  • Reset the player back to factory default settings and try again.
Cheerd
