GPS-CS1 MALFUNCTION
brhatho
Nuevo miembro
GPS-CS1 MALFUNCTION
I have two gps-cs1 unit kits. Both have stopped getting correct date & time info, so guess it's a satellite problem.I have heard it may be due to satellite rollover a bit like Y2K problems. Can anyone help, please?
5 RESPUESTAS 5
Piscie
Hey @brhatho have you tried resetting both units to factory settings?
brhatho
Nuevo miembro
Hi Piscie, thanks for your input. Unfortunately, GPS-CS1 has minimal controls. Apart from "ON/OFF", there is a "Clear" button which just clears the memory. When connecting to a computer, there are no usable controls. Shame to discard a fantastic piece of kit for something probably being foistered on us by the powers-that-be.
Regards
Piscie
Hi brhatho, yeah that must be frustrating! But I'm afraid the device is too old, so I'm not sure if the repair centre still affords spare parts or not, you may need to check with them directly: https://www.sonypencoed.co.uk/contact/
brhatho
Nuevo miembro
Hi again Piscie, yep, I guess it's time to get a new one. Such a shame it is (was?) perfect. Lightweight and only one AA rechargeable battery lasted all day. Progress? I don't think so. Instant download with Breeze Downloader Pro: super!
Regards
kev_bite
Nuevo miembro
I've hit the same problem today, it seems that it's possible to work around the issue by manually editing the `.log` files.
each log file has a `$GPRMC` message which includes the date. For example.
$GPRMC,130056,A,1310.5123,S,07233.2770,W,000.3,000.0,230404,,,A*7D
230404 within this message is the date of 2004-04-23, if you update that to be the correct date then you're back in business!
