Can I use xperia e 4 without sim?
Iida
Visitor
Can I use xperia e 4 without sim card?
1 ACCEPTED SOLUTION
Uliwooly
@Iida
yes you can, but you won't be able to make nor receive calls nor send/receive SMS/MMS
3 REPLIES 3
Uliwooly
@Iida
Iida
Visitor
Thanks,
I will not need to call or SMS, just want to be able to access the data.
Martin1
Enthusiast
Hi @Iida, let me see if I can answer your question.
If the only purpose is to access the locally stored data on the phone, you can absolutely use the phone without a SIM card. If you want to access the Internet for some reason, you will need to connect your phone to a Wi-Fi.
Let me know if there is anything else I can help you with! Slightly_smiling_Face
