Partilhe a sua experiência!
Gostava de saber se máquina DSC-F707 pode usar o adaptador memory stick?
Solucionado! Ir para a Solução.
Caro luispmorais,
Bem-vindo ao forum da Sony...
Esse modelo é compatível/ou não com qualquer os seguintes Memory Stick...
Tipo | Modelo | Capacidade/Classe | Compatibilidade |
![]() Memory Stick (com MagicGate) | MSH-32 | 32MB | • |
MSH-64 | 64MB | • | |
MSH-128 | 128MB | • | |
MSH-128S2 | 256MB | • (*1) | |
![]() Memory Stick Duo (com MagicGate) | MSH-M32N | 32MB | • (*4) (*10) (*11) |
MSH-M64N | 64MB | • (*4) (*10) (*11) | |
MSH-M128N | 128MB | • (*1) (*4) (*10) (*11) | |
![]() Memory Stick PRO | MSX-256S/X | 256MB | X |
MSX-512S/X | 512MB | X | |
MSX-1GS/X | 1GB | X | |
MSX-2GS/X | 2GB | X | |
![]() Memory Stick PRO Duo | MSX-M256S/X | 256MB | X (*11) |
MSX-M512S/X | 512MB | X (*11) | |
MSX-M1GS/X | 1GB | X | |
MSX-M1GST/X | 1GB | X | |
MSX-M2GS/X | 2GB | X | |
MSX-M4GS/X | 4GB | X | |
MSX-M8GS/X | 8GB | X (*9) | |
![]() Memory Stick PRO Duo (Mark2) | MS-MT1G | 1GB | X (*2) |
MS-MT2G | 2GB | X (*2) | |
MS-MT4G | 4GB | X (*2) | |
MS-MT8G | 8GB | X (*2) (*9) | |
MS-MT16G | 16GB | X (*2) (*9) | |
MS-MT32G | 32GB | X (*2) (*9) | |
![]() Memory Stick PRO (alta velocidade) | MSX-256N | 256MB | X (*2) |
MSX-512N | 512MB | X (*2) | |
MSX-1GN | 1GB | X (*2) | |
MSX-2GN | 2GB | X (*2) | |
![]() Memory Stick PRO Duo (alta velocidade) | MSX-M256N | 256MB | X (*2) (*11) |
MSX-M512N | 512MB | X (*2) (*11) | |
MSX-M1GN/X | 1GB | X (*2) | |
MSX-M2GN/X | 2GB | X (*2) | |
![]() Memory Stick PRO-HG Duo | MS-EX1G | 1GB | X (*2) |
MS-EX2G | 2GB | X (*2) | |
MS-EX4G | 4GB | X (*2) | |
![]() Memory Stick PRO-HG Duo HX | MS-HX4G | 4GB | X (*2) |
MS-HX8G | 8GB | X (*2) | |
MS-HX16G | 16GB | X (*2) | |
MS-HX32G | 32GB | X (*2) | |
MS-HX8A | 8GB | X (*2) | |
MS-HX16A | 16GB | X (*2) | |
MS-HX32A | 32GB | X (*2) | |
![]() Memory Stick com TransferJet | MS-JX8G | 8GB | X (*2) (*12) |
![]() Memory Stick Duo PSP | PSP-M32 | 32MB | • (*4) (*7) (*10) (*11) |
![]() Memory Stick PRO Duo PSP | PSP-MP1G | 1GB | X (*7) |
![]() Memory Stick Micro (M2) | MS-A256A | 256MB | X (*11) |
MS-A512A | 512MB | X (*11) | |
MS-A1GA | 1GB | X (*11) | |
MS-A2GW | 2GB | X (*11) | |
MS-A2GN | 2GB | X (*11) | |
MS-A2GU | 2GB | X (*11) | |
MS-A4GN | 4GB | X (*11) | |
MS-A4GU | 4GB | X (*11) | |
MS-A8GN | 8GB | X (*11) | |
MS-A8GU2 | 8GB | X (*11) | |
MS-A16GU2 | 16GB | X (*11) |
Ola luispmorais! Seja bem vindo ao forum Sony!
Qual seria o memory stick que voce menciona? É o proprio "memory stick" (aquele maior, antigo) ou tem um nome e modelo?
Cumprimentos.
Caro luispmorais,
