- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I'm trying to find a way to either specify which sim to be used when calling a specific phone number (based on a pattern ot per-contact setting) or at least have the ability to select the sim every time i make a call. Sim Selector and similar utilities are almost working, but all of them fail to actually change the active sim. Do you have any ideas? My need of such featuer is critical, because I'm using 2 sim cards from different providers in order to save money and the inability to dial different numbers from different sims renders the whole dual-sim feature completely useless.
Thanks,
Daniel
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Use Sim Selector. option in the settings 5 and the delay 0,5 sec.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have same trouble about option dual sim, often we choose mobile with 2 sim card is for use 2 sim card that can choose sim1 or sim2 to call or sms, but in Xperia C no option like that, it only default sim for call & sms. please make upgrade for this issues.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
The second SIM cas be used on GSM only,the phone is dual standby.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
i can use both sim for outgoing calls and data. the problem is that when i'm making a call i have to switch the active sim manually. there are apps in google play that can match phone number patterns and switch the sim for me when i make a call. all of them correctly suggest the new active sim, but on xperia c they fail to actually change the sim. i guess the system call for programmatically changing the sim fails.
i need this funtionality to work, in order to utilize discounts when calling within the same mobile network. my 2 sims are from different mibile operators, lets say A and B. if i call from sim A to a number on the network A, or if i call from sim B to a number on the network B i'm paying much less than when calling from A to B and from B to A.
currently i have to check the number i'm going to dial and manually change the sim card, if the number is on the other network - an operation that is very easy to automate, especially when there are already tools that can do the thing on other phones.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
you can try pixel phone on googleplay store
if call out youcan choose sim1 or sim2
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
SIM selector option id disabled...how to add time delay for SIM selection??
