Whats the difference between XR-50X94SU & XR-50X90SU
j0nnye
They both are priced identically on currys, both look like they have exact same specs, but cant see what the difference is?
1 ACCEPTED SOLUTION
LightFoot
Specialist
Hi @j0nnye
In very general terms, the higher the number (94) the better the spec. You need to carefully compare specifications below. A very quick scan shows different Remotes, Rich Colour Enhancer, built in Mic on the 94. There may be others. Sometimes (may not be in this case) slightly different stands.
Support for XR-50X90S | Sony UK
Support for XR-50X94S | Sony UK
3 REPLIES 3
HannahEd01
Hey there, the only difference is that the XR-50X94S has a built-in mic :grin:
LightFoot
Specialist
Hi @j0nnye
SkyNet404
Specialist
Also, one of them will be a Sony only exclusive on their online store, I believe it's only the 94S.
