Sony AG8 click noise
Mike8819
I have just purchased a Sony 55” AG8 OLED tv, very happy overall with the image quality, but I have one concern, when I turned the TV off and on via the remote I heard a click/ping noise! It only happens when turning the unit on or off, can anyone tell me if this is a fault or is this normal?
1 REPLY 1
Jasperf236
Yes completely normal had my TV for 7 months. And clicks the same as yours.
