Sony AF8 eARC
profile.country.NO.title
janpfo
Sony AF8 eARC
  • Do you have any plans to update this TV to support eARC? Can we get a confirmation that you plan to update it, or that you never will update it? After looking at the schematics, it looks like the chipset supports eARC. I need a confirmation, because if you won't update the firmware, I'll have to buy a new TV (not a Sony this time)...
Tags (4)
7 REPLIES 7
Personal opinion, I don't think Sony will add eARC to AF8. Sorry for the question, but for what reason would you like eARC? What do you need to connect that requires it?
janpfo
I have pre-ordered a Sonos Arc, and I only watch BR movies with True HD audio track. I'm very happy with the TV, and the only downside is the missing eARC connection. I don't want to buy a new TV after 1.5 year because I need eARC.
I can understand why they don't upgrade it to Android Pie, and personally I don't need it. But from my understanding, it supports eARC, but they won't update the firmware.
Ok I don't add more then, I asked it because many don't know that Atmos on DD+ (for example) is also conveyed on ARC, but not a TrueHD track...
janpfo
It looks like the ATV4K don't support this, it needs a eARC connection.
janpfo
So no comment from Sony on this?
Darek.1
Hi, i’m also interested in upgrade to eArc. Is it really technically possible? How can this be formally requested by Sony?
Win_88
Specialist
A few models have received updates to enable eARC over the past few months. Not sure if the same will happen with the AF8 though. But it's a possibility.
