Hi ,
When i try to type somthing on youtube or on the internet the tv keyboard is not showing and i have just voice control to type in.
THank you
Hi there
When doing a search via the YouTube app, the default is the voice search. If you press the Right Arrow button on the remote control TWICE it will then highlight the text box and the onscreen keyboard should then be displayed. Im assuming this will also be the case when using the web browser too.
Cheers
Hi
I have this problem tpp seems to have developed on last system update, does anyone know a fix?
