- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Prime 4k content finding & playing
finding it is now a right PITA, has anyone discovered an easy way to find content
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
No. Amazon seems to be hiding it on purpose.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@Prior20 wrote:finding it is now a right PITA, has anyone discovered an easy way to find content
Try going into the Search option and typing 4K, UHD, or one of many similar search terms, some of which may appear there for you there once you have input something related.
You can carry out the same sort of process on Netflix as well.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
That doesn't work, you won't find any 4K or UHD content on Prime Video that way, the only way is to scroll manually through the list.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Well, that's a pain then, and it must be to do with the version of Amazon Video on these TVs
As it works perfectly well on my iPad and my Android phone, as well as on my Amazon FireTV and Firesticks.
Maybe then, downloading the Amazon Video app to your mobile/tablet and using that for such searches, while not the ideal solution, will help for the moment?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Just tried the app on my Android phone and again searching for 4K or UHD just gives me the standard results. Very strange.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@stormyuk wrote:Just tried the app on my Android phone and again searching for 4K or UHD just gives me the standard results. Very strange.
Yes, very strange indeed. None of the results show the 4K/UHD indicator, even though some of them say they are UHD (e.g. The High Sierra), and all of them could plausibly be available in UHD. Yet none of them seem to attempt to go into UHD.
If I pick something that definitely is UHD, e.g. The Last Tycoon, it says it is UHD, and attempts to show it in UHD.
(Amazon fails in this, though, and drops to HD here, from my Amazon FireTV to my Samsung UE55HU8500, even though I am taking care to use the HDMI/MHL port, which supports the required HDCP 2.2, and I have five times the required 15 Mbps, and WiFi to match. But ho-hum, that is a different issue, and at least it attempts UHD).
I wonder why the Amazon Search is so broken on tablets and smartphones?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
To me it looks like they are hiding 4K/UHD on purpose. Probably to save bandwidth.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Prior20,
Your question has been asked and answered frequently here. You could find good responses by searching the forum.
To answer your question, the Prime Video app executes Internet connection tests at startup. They also test various factors on the quality of your connection in the background such as network access, latency and throughput speed. If the results don't satisfy their minimum requirements for streaming UHD content, the Prime Video app will automatically refrain from suggesting UHD content, as well as defaulting back to HD content in the event you select a native UHD content for playback. This behaviour is not a fault but implemented by design through Amazon.
The suggestion is to upgrade your Internet connection to at least 40 mbps and connect your playback device using a wired connection as oppose to a wireless connection.
Cheers,
Dutchice
