kdl40w705c flashing white light
Ziakiwi
My bravia has turned off and has a flashing white light in centre below the screen. This has happened before and unplugged and left for a while and then it would go back to normal. But it's been 2 days and I've unplugged and plugged back in numerous times but it won't reset and start.
Please help
2 REPLIES 2
Pascale_F
Moderator
Hi Ziakiwi,
I'm just going to try to find some answers for you. In the meantime, maybe someone else in the community might have some ideas.
Thanks,
Pascale
Win_88
Specialist
Hi Ziakiwi,
Have you tried resetting the TV? You can find the steps here: https://www.sony.co.uk/electronics/support/televisions-projectors-lcd-tvs/kdl-40w705c/articles/00032...
Win_88
