KD49X F8505 When Watching All Four it starts buffering, on return to TV screen is blank, resets ok.
Calsatch
5 REPLIES 5
LightFoot
Specialist
Hi @Calsatch   I would start by checking that your software is up to date.
Firmware update to v6.7220 | Sony UK
Calsatch
Channel 4 on catch up!  Firmware is up to date, thanks
EMS_MO72
Hey @Calsatch
did you try to disconnect the TV from the mains and leave it for 2 minutes and then check again?
also, if possible to disconnect any external devices
Calsatch
Yes, (as in resets OK), it seems a problem with channel 4 on catch up, if we wait it eventually stops buffering, but it's a pain.
SatoruGojo
@Calsatch, you can try the factory reset in that case.
