- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
KD-55XD7005B - HBO GO and Bluetooth connectivity
Hello, i'm new to Sony and i would like to post 2 questions regarding my new Android TV.
1. Does Sony's AndroidTV support HBO GO official app? I can't find it on PlayStore.
2. What up with the Bluetooth settings when i try to add deviaces from TV, the setup gets stuck in searching for deviaces, the TV can't find anything but when i connect my phone to the TV works without any issues.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @Gabriel.is, welcome to the community
- I found HBO GO in the PlayStore, but it looks like it's only accesible in the US. What country are you in?
- Have you tried the troubleshooting steps for this issue in the Help Guide? (The Help Guide can be found on this page)
Cheers,
Cass
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
1. I'm from Romania, it's not there for me .... when i tried installing with Playstore using pc it says No carrier Sony BRAVIA 4K GB .
2. Did that, i don't think it's product lock for specific type .... if i connect with other deviaces like smartphone, laptop, tablet it works, even my Samsung tv can find this Sony and the pairing works perfect, but when i try to search with the Sony TV i can't find anything, already did a factory reset and nothing....
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
The list of supported Bluetooth devices for the KD-55XD7005B is limited, so it’s likely that the devices you’re trying to connect are not compatible. You can see the list of supported profiles here.
Cheers,
Cass
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I know about the list, that's why it's strange why this Sony won't find my Philips AEA2000/12 Bluetooth adapter because the supported profiles are A2DP and AVRCP, every gadget in my house can find and pair with it easy but not this TV.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have looked into this for you and the KD-55XD7005B model doesn't support the A2DP profile I'm afraid (this is only available for XE85, XE90, XE93, XE94 and A1 Series).
Cheers,
Cass
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Sony should change the info in help section on tv's menu, i'm sure that's a software rectriction to make other tv's more special.
As for HBO support I managed to transfer the app from my Phone to the Sony TV and it works, I had to use my k400 from logitech to move the scroll around and select menu's. The thing is this was just a test, clearly I can't use this app for tv because is meant for touchscreen.
