- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
KD-49X8305C Software update crash 64%
Contacted Sony - all their attempts failed.
I tried installing the latest firmware update V2605 online through TV( I have 150Mb cable), also downloaded the firmware and put onto a USB(tried the two file method also).
Every time, via TV setting software update, the download crashes at 64%(states "An error occurred during the software update, . The update server in temporarily unavailable. Please try again later Error: 2123).
The usb( usb slot 1 and 2 tried) method also crashes out into reboot at about 64% too.
Downloaded the firmware numerous time.
Any ideas ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@Ralph53 - is your tv connected to the interner, if so you dont need to download it to usb, just do a system software update on the tv via the help menu.
If you cant do that, the detailed instructions are located where you downloaded the usb firmware update.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi
I have a KD-55X9305C, it has not been able to update since getting out of the box, I have it hard wired and it wont auto update, crashes same as all the other comments here;
I have attempted numerous manual updates using a USB drive and the sony firmware downloaded from their support site; last week with the previous YouView update and now with the latest v2645
As usual it gets to about 81% then hangs and cuts out. TV reboots about 3 times and again update has failed.
I would VERY much appreciate a fix, if anyone can describe how they have got their updates to work I would be very grateful
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@Boba77Fett - ive sent you a private message with some instructions. Let me know how you get on.
Cheers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@Anonymous as I said in my PM it worked and many thanks to you for the help.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi, I have a kdl 43w756c that fails at 71% on updating. I would appreciate it if you could help. Thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
I have replied to your PM with some instructions. Let me know how you ge on.
Cheers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
That worked a treat! Thanks for your help
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi, I have a kd-49X8305c that fails at 71% on updating. I would appreciate it if you could help. Thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
Ive sent you a private message with some instructions. Let me know how you get on.
Cheers
