ITV ch grayed out on ITV Hub
John1950Hitchin
Member
Hi all, ITV is not selectable but the other ITV chs are. I get my signals from Sandy and are very strong. I have retuned after clearing the Youview cache. When a program is selected on the youview screen it tries and then gives an opps error. I have the 8th March update and 150Mbit connection.
Any ideas?
Thanks.
John
KD49X8309C
11 REPLIES 11
mshopkins1
Did the problem with The ITV hub get resolved?  I have the same problem on my new Sony Bravia KD49XH8505
and can’t get ITV. I Can get all the other channels ITV2, ITVBe, ITV3 etc.
Tags (1)
royabrown2
Hero
@mshopkins1
Do you live in Scotland?
You get STV, not ITV there, and even though you get the ITV Hub, you don’t get the main ITV channel.
