Hi. Recently new too Sony and the ir blaster,
i have been been trying to set it up to use with my sky q 2tb box and no matter how many times I try it doesn’t work.
Has as anyone been able to get this to work or is it not compatible?
Thanks.
@Adamhotson7887 wrote:Hi. Recently new too Sony and the ir blaster,
Thanks.
Hi @Adamhotson7887 To the best of my knowledge only Sky+HD is supported. I have a Sky Q 2TB box and can confirm it doesn't work. However I haven't tried it since the Oreo update. If you don't see Sky Q in the list then no chance.
@LightFoot No I only see BskyB & Sky TV, that’s shame tho but it’s atkeast cut down my remotes from 4 too 2.
It works perfectly with BT TV box which is a bonus.
