Iplayer,itv player,channel 4 and 5 on catch up not loading on my tv
Nookey2
2 REPLIES 2
LightFoot
Specialist
Hi @Nookey2   What is the model number of your TV I.e. KDxxxxxxxxxx. You should note a factory reset cures most problems.
Nookey2
Thanks but I managed to solve the problem ...I hadn’t put on the apps properly and then all I needed to do was turn the tv off and on and then they all worked 😁
