Channel 799
RobertHallas
Membro
Channel 799
hi, when I go to TV guide, I keep getting the message ‘retune to channel 799’! and this takes me to channel 799, although I have clicked on a different channel, it’s a real pain! Anyone know how to get rid of this? Thanks.
17 RISPOSTE 17
LightFoot
Specialist
Hi @RobertHallas
It is difficult to provide specific advise without knowing the full model number of your TV.
Have you tried a full refresh of your Freeview channels? On my TV it is Settings -> Channels & Inputs -> Channels -> Channel setup -> Auto tuning -> Aerial Digital Set up -> Set up again? etc. etc.
RobertHallas
Membro
Hi, thanks for the prompt reply,
my model is KD48A9S. Thanks.
LightFoot
Specialist
Hi @RobertHallas
Did you try the channel refresh? Your manual for your KD-48A9 shows.
https://helpguide.sony.net/tv/haep1/v1/en/02-01-02_01.html?hl=retune
RobertHallas
Membro
Hi, thanks for the reply, I have retuned as you suggested, but it makes no difference!?
 I don’t know what else to do. Thanks for your help.
RobertHallas
Membro
Hi, I tried the reset, but it didn’t work, it’s still the same!?
LightFoot
Specialist
Hi @RobertHallas
I'm afraid that you may be in the Reset territory. I would try a soft reset first and if that doesn't work a full factory reset. This often cures these type of glitches.
How to reset your Sony TV with or without the remote (soft restart, power reset or factory settings)...
Have you checked that you are running the latest software? It seems strange to me that your model's last update was 03/09/2021.
Firmware update to v6.5076 | Sony UK
Failing everything, it is contact Sony Support.
Sony Support Consumer Electronics
Edit: Sorry, I see our posts crossed.
tihardi69
and me, same model
LightFoot
Specialist
Just out of interest (a photo may help). It is not a standard message telling you that the channels are changing on your transmitter and you may have to retune in the future?
tihardi69
mine is the same even after reset
