Android 8.0 Oreo/ 9.0 Pie
zlays84
Member
Is it OK to expect Android Oreo on 2017 Sony Android TVs?
641 REPLIES 641
stormyuk
Looks like only the ATV3 TVs, even the 2019 XG9005 isn't on the list.
Edit: Looks like its the ATV3 TVs from 2019 and a couple of 2018 TVs in the US at least (Z9F and A9F).
miscofi
Member
Confirmation from Sony that 9Pie is on the way
Says it's in stages so other models may get it later also
https://www.sony.com/electronics/support/articles/00231372
profile.country.NL.title
pa3eia
Very very soon, only updating from support.
On the AG's, ZG's and the high end XG models incl. Airplay and Homekit.
73's
Thanks about the Kudos!!!
miscofi
Member
Are there two updates ? November and December ?
profile.country.GR.title
Lefteris21ps
Member
Benefits and Improvements from the latest update
  • Fixes an issue where Netflix does not play UHD 4K or Dolby Vision content properly when AD2P headphones are connected
  • Upgrades the operating system to Android™ 9 Pie and adds the following features:
    • Support for Apple AirPlay® and Apple Homekit™
    • Integrates Dolby ATMOS support with the TV speakers
    • Support for HEVC 100/120Hz format for USB video playback
    • Combines the Video, Album and Music apps into the Media Player app
    • Redesigns the Setting and Quick Settings menus
    • Allows you to customize the Input menu
    • Redesigns the Restart menu
    • Redesigns the TV menu
    • Redesigns the Guide screen to display the current channel in a small window within the screen
    • Adds a Timer icon to the Home screen
    • For models that have an IR Blaster, the IR Blaster setup function is renamed to Cable/Satellite box setup
    • Redesigns the LED illumination behavior when using OK Google
    • Provides additional menu, interface, and icon enhancements
npapanik
Member
The update is for US models not for the European ones...
They are planning and update for the Android 8.0, see here:
https://www.sony.co.uk/electronics/support/televisions-projectors-lcd-tvs-android-/kd-49xf9005/artic...
KD-49XF9005
HT-CT390
Lefteris21ps
Member
This update is for usa models but the similiar will get it models with new hardare board,atv3,i think af9 and after
Pat100
Member
There are two updates currently available from Sony (Timing dependant on locality)
One is is a small update to Android Oreo. (Only for a limited number of sets e.g. not my XG95)
The other is a large update from Oreo to Pie.
miscofi
Member
Thanks for clarifying that
Pat100
Member
Oops! I forgot to add my get-out: AFAIK :slight_smile:
