Android 8.0 Oreo/ 9.0 Pie
zlays84
Member
Is it OK to expect Android Oreo on 2017 Sony Android TVs?
641 REPLIES 641
marcobremb
Member
Rolling out tomorrow. FINALLY
zlays84
Member
Here's official video:
https://youtu.be/qhhNZmNj8JY
The Android 8.0 Oreo update will be available from 30th January 2019, and we plan to distribute this update in waves. The easiest way of receiving this update is by ensuring that the Automatic software download setting on your TV is turned ON. Your TV should then receive the update automatically ...
Hakki.Gulmez
Hi guys, I'm here now in Turkey and 00:27 hours and dates from 30 February, so why are you still did not support Oreo update their sites?
profile.country.AT.title
Kuschelmonschter
Hero
Itom86
Member
Also available in the UK.
novalu
In Czech Republic OTA wasn't available, but I've downloaded Oreo and install it via USB without any problem. Oreo looks great.
Hakki.Gulmez
friends, I've installed the oreo update with usb, but I'm not happy at the moment, if you say why; 1080p and 4K videos that I play before do not open now, there is also a problem with DLNA streaming 😞
Itom86
Member
This is a known issue, that everybody is complaining about in the US. I guess I'll just stick with Nougat, until they find a solution.
Kuschelmonschter
Hero
Yes. The Video app is totally broken. It hardly plays anything and often puts the TV in an inconsistent state. Kodi is fine though. You just have to disable DTS and DTS-HD passthrough which the TV pretends to support. It however does not work.
zlays84
Member
I really don't understand I'm testing all my 4K demo videos with high bitrate and al movies everything on external hdd (not even usb 3.0 but the older 2.0) and everything is working flawlessly...
I did a factory reset after update...
