Amazon Dot / Echo - Integration
Prior20
Member
Are there any skills / integrations for sony android TVs ?
2 REPLIES 2
Anonymous
Not applicable
Hi there
This is something Sony will not support - however if you google around, there are some info and advice.  I also found this video below
http://androidtv.news/2016/07/get-amazon-echo-tv-alexa-listens/
Unfortunately I can only google links for you (which you can do), as I do not have any experience on this device.
Cheers
Prior20
Member
Thanks, will take a look.  Though sony may have looked to support
