I am about to buy an A7rIII but will have to wait a while before I buy any FE lenses to use with it. I have a number of a-mount lenses from my a77 but these are apsc rather than full frame. Does anybody know if I will be able to use apsc lenses on my a7riii using the Sony LA-EA4 Mount Adapter?
Hi danilow,
I will try to find out for you. In the meantime perhaps someone else in the community may know if this is possible.
Best wishes,
Sean Mc
Hi danilow,
You can find a list of the compatible A mount lenses with the LA-EA4 adaptor in this link: http://support.d-imaging.sony.co.jp/www/cscs/accessories/compatibility.php?area=gb&lang=en&mdl=LA-EA.... Each lens will have a description to let you know what to watch out for and if there are restrictions to keep in mind.
Win_88
