does anyone have experience re shooting at slower shutter speeds in low light conditions, I have the option to use either the a7 or the a9. I am trying to avoid camera shake, for various reasone tripods not an option.
Also do any 3rd party auto focus lenses work particularly well with either of these 2 bodies,
Thanks
Hello @ldn1818,
if a tripod is not an option, i would advise against slow shutter speeds - instead I would increase the ISO and live with the images having a little more grain.
With both of your available cameras, that shouldn't be an issue though.
- Nic
