I am thinking of buying an A7Cii. Using my RX100m6 I have not been able to set it up to work remotely from my Iphone. Looking at the feedback for the Creators app. which should work with the A7Cii( called ICL7C2 by Sony in the app), the feedback is mostly awful. This could be a reason for not choosing Sony, or have they got the app working well now?
Hey @Ianto7
I can see that the ILCE-7CM2 is compatible with remote shooting with the creator's app: https://www.sony.co.uk/electronics/support/e-mount-body-ilce-7-series/ilce-7cm2/articles/CCCA03001 , however, I don't see the RX100M6
And this is how you can remote shoot with the A7Cii : https://www.sony.co.uk/electronics/support/e-mount-body-ilce-7-series/ilce-7cm2/articles/CCCA06005
A7C2 now working with the Creator app ok, thanks
