RAW Files from Sony A6700
rabeckw
Want to check RAW files from camera are working OK before taking it on holiday shortly but no software update available yet from Capture One, Adobe, Luminar or Affinity possibly for 1-2 months. Does anyone know of a software that will handle these RAW files now. I use a MAC. Thanks
1 ACCEPTED SOLUTION
danardeng
Contributor
2 REPLIES 2
danardeng
Contributor
rabeckw
Thank you, After downloading a second file which the original requested I can see my RAW images and manipulate to a degree.
