LCD screen stopped working when changing ISO / SS
Laughs
Hey,
For some reason my a7iii LCD screen has stopped changing the preview when ISO / SS is altered - happening in all modes.
It was working completely fine earlier so no idea what has changed.
If I do adjust ISO or SS the image will take with the settings I have adjusted - I just cannot see the preview via LCD or viewfinder
soooo annoying!!
Any help would be amazing
3 REPLIES 3
Laughs
Update - it works if I map Shot. Result Preview to a custom key
danardeng
Contributor
Anonymous
Not applicable
Hey @Laughs
did you try what @danardeng suggested? Did it work with you?
