Image Edge Mobile Software disconnects
Fredrik_12
When shooting with a client on set, it is very very nice to be able to hand over an iPhone or an iPad to the client. Then the client will be able to see and discuss images as we go.
You can do exactly this in "Image Edge Software", however, I can't see the images in my camera. As soon I look on the previous image in camera, Image Edge Mobile will disconnect.
Sony, fix this and you will have a killer feature.
1 REPLY 1
EdwinaU
Moderator
Hi there,
Thanks for sharing your thoughts about this feature and posting your feedback here.
Best wishes,
Ed
