Filter reflections when using Sony FE 16-35mm F4 ZA OSS lens
Tony-Cowburn
Has anyone else noticed image defects when using the Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS with filters? The problem is that the white lettering around the front of the lens gets reflected in any filters used (eg ND's,ND grads, etc) and the reflections cause a semi circular ring in the image. One of my friends had this issue and he returned the lens and bought something different. Somebody else posted this online to describe the issue: https://www.dpreview.com/forums/thread/3841617
It is a major issue for landscape photographers who always use filters, and it make this lens unusable in its current form. Are any other landscape photographers seeing the issue? Does anyone know of any plans for Sony to address the defect?
7 REPLIES 7
EdwinaU
Moderator
Hi Tony,
Welcome to the community.
We will look into this and update you when we know more.
Meanwhile, some of our members may have some experiences to share.
Best wishes,
Ed
Vanilla_
Contributor
Hi Tony-Cowburn,
I've checked the photos on that link. I'm not sure if this can be caused by the lens or the camera. Let us know what is the camera you're using,  maybe we can look this up here.
Vanilla_
profile.country.CZ.title
Hefi26
Member
Hello, I have the same problem but I haven't met him for the first time. Already with my previous equipment (Panasonic Leica 8-18), I have seen the same problem. Now with the Sony 16-35 F4, using both transient and ND filters, the lens reflects the lens (or the inscriptions on the front of the lens). I have found that the degree of F-number used has a great impact on it, so the higher the F, the more the reflection becomes apparent.
I decided to solve this problem by masking the lens on the front of my lens (in my opinion, the problem is that there are so distinctive white markings on the front of the lens) using a black felt-tip pen, which should not cause any damage and, if necessary, will remove this masking using cotton buds and alcohol.
If there is another solution, please inform.
Thanks in advance
Vanilla_
Contributor
Hi Hefi26,
Thanks for sharing this solution with us. Are you using a Sony camera as well?
Vanilla_
Hefi26
Member
Hi, yes I use Sony A7
Vanilla_
Contributor
Hi Hefi26,
They seem to be compatible! Are they running the latest firmware version?
Here's the update for the lens: https://www.sony.co.uk/electronics/support/lenses-e-mount-lenses/sel1635z/downloads/00014669
And here's the camera:  https://www.sony.co.uk/electronics/support/e-mount-body-ilce-7-series/ilce-7/downloads/Z0005422
Regards,
Vanilla_
Hefi26
Member
