HSS wireless flash with HVL-43M off camera AR7II
Burg16
I want to fire my HVL-43M flash ( off camera) using HSS. Can this be done using the smaller HVL-F20M as on camera flash controller ? Or is there another way ?
Tags (1)
1 ACCEPTED SOLUTION
Almou_10
Specialist
Hi Burg16,
I guess since the HVL-F20M is the one not compatible with HSS, thus, the whole setup won't work in HSS.
This can be be achieved if you have a 2nd HSS compatible flash.
Hope this helps.
Almou_10
3 REPLIES 3
Pascale_F
Moderator
Hi Burg16,
I'm not too sure about this, but I'll see if i can track down an answer. Maybe someone else in the Community has an idea in the meantime.
Thanks,
Pascale
Burg16
Thanks.
I think I read somewhere that using the HVL20M as a controller will do TTL bhut not HSS.
Almou_10
Specialist
Hi Burg16,
Hope this helps.
Almou_10
