I am a landscape photographer who uses remote control shutter release (for Bulb exposures) but also wish to geotag my images. The problem is that both the RMT-P1BT wireless remote commander and Imaging edge use bluetooth.
You cannot have both.....any solutions sony?
I have to say that Sony are the least responsive to user input than Canon or Nikon so i don't have too many hopes.
Solved! Go to Solution.
Hi there,
As far as I know, it's not possible to geotag pictures when using the remote or via Imaging Edge (as of yet).
Let's hope this gets added in a future update
Win_88
Hi there,
I'll look into this, and a community member will get back to you.
Best wishes,
M
