Hi some help with a quandary please.
Read so many reviews without conclusion so hoping I can get some pointers here instead.
The lens will be used for covering U18 and Adult Cricket at club level images are not to be sold and my camera is the A7iii.
So which to buy??
Hi there,
This is a complex decision and you need to consider factors like sharpness, distortion, speed, prime or zoom, and most importantly, price as both these lenses are at the higher price range.
Perhaps another member of the community might be able to offer their expertise advice, or perhaps speak to your local camera retailer who will be able to answer any further questions you may have.
Best wishes,
Sean
Hi Sean
Thanks for your response, I've gone for the 200-600 for the extra reach.
Nice choice. I wish you all the best with your new lens. 😊
Best wishes,
Sean
