Just upgraded my firmware on my A9 and now testing the wifi sending to my server. I've set it up and it works just as well at my Canon 1DX MK2. The only problem is if I continue to shoot whilst sending the sending image corrupts.
Any one else having this issue or can Sony offer any advice.
Cheers
Hi there,
Can you confirm that you have the Software update Ver.4.10? You can check the details on this here.
Best wishes,
Sean Mc
Hi again,
I would recommend getting in touch with the support team who will be able to advise further here.
Best wishes,
Sean Mc
