File Transfer whilst shooting
malcy1970
Just upgraded my firmware on my A9 and now testing the wifi sending to my server. I've set it up and it works just as well at my Canon 1DX MK2. The only problem is if I continue to shoot whilst sending the sending image corrupts.
Any one else having this issue or can Sony offer any advice.
Cheers
4 REPLIES 4
Sean_Mc
Moderator
Hi there,
Can you confirm that you have the Software update Ver.4.10?  You can check the details on this here.
Best wishes,
Sean Mc
malcy1970
Yes I can confirm the Firmware is uptodate with Version 4.10.
Any ideas.
I can send to my FTP server easily enough but if I shoot whilst sending the file sending corrupts.
Cheers
M
Sean_Mc
Moderator
Hi again,
I would recommend getting in touch with the support team who will be able to advise further here.
Best wishes,
Sean Mc
malcy1970
Thankyou,
I think it might be my memory cards that are not up to the job. Camera keeps freezing as well. I’ve been told be several sources that I need to get the Sony cards.
More money.
M
Sent from my iPhone
