Hi
I have tried to upload to my A6400 the apps I used on my A6300 and it will not allow it. I have connected the transfer to phone app so this allows me to control the camera through my I phone and this was using imaging edge.
are the apps Like "shutter release" downloaded able or have I bought the wrong camera as I see the apps are compatable with A6000 A6500
I am confussed and frustrated as Google says they are scrapped by Sony
Cheers
Hi there,
I will look into this, and a community member will get back to you.
Best wishes,
M
Hi periddi
It seems the ILCE-6400 doesn't support PlayMemories apps, instead, it's compatible with Sony's new Imaging Edge software.
Win_88
