Hi.
I just got my A7iii and attached my Peak Design Slide strap to it. Right away I noticed that my shutter hand was hurting when holding a camera. Especially with heavier lenses like 70-200mm or 150-600mm. Plastic piece of the strap ring/triangle was scratching/hurting side of my front finger. Removing this piece solved a situation. Placing the holding triangle and sharpness of the piece could be revaluated.
Hi Promaximus,
This sounds frustrating - I will pass on your feedback to the team.
Thanks,
Pascale_F
