Xperia 10 Plus Homescreen Apps Positioning Bug
Xenitism
Visitor
 I disable the google search bar for the homescreen and the apps I customized on the position of the search bar are randomly pushed up to an upper row. It usually happends after a reboot but sometimes after I go back to homescreen too. Please help if there is solution out there. Thank you!
7 REPLIES 7
eddymjj78
Visitor
I have the same issue. It's a bug of this stock home. I add the search bar since 2 days and no problems.
I notice that the stock numeric clock widget take it's normal size even if the alarme is actived and on this widget now. Not the case when I disable the search bar.
Xenitism
Visitor
Been using for days without search bar and it happened once more again. Hope sony can actually remove the bug even though it's an insignificant bug.
eddymjj78
Visitor
Yes. This new Xperia home need an update.
For the moment we must enable the search bar to skirt these bug. The other way around the bug is to not create a second home page.
eddymjj78
Visitor
It seems that this bug is corrected in May system update.
Xenitism
Visitor
Not sure it's the latest update. My software version is now 53.0.A.4.114 and the bug still exists
eddymjj78
Visitor
In fact this bug is still here.
NEOMERCER
Visitor
For me, the play store app and Google folder got moved up once. I've also noticed that the Google search bar setting will be switched to on sometimes, even though I know there isn't a search bar there anymore. I've only had this phone for a few hours but there is definitely a lot of bugs that I have noticed already.
