Xperia 10 IV usb tethering
profile.country.DK.title
TorDen
After updating to android 14 my xperia 10 IV cannot usb tether to my router,
android 12 and 13 was working fine, I have been in contact with Asus and they
say it is a Sony problem, have others experienced the same problem ?
6 REPLIES 6
Altiar
Hey @TorDen can you tell us more about the issue so we would be able to assist? Also, you can check how to enable it as shown here.
TorDen
Android 12 and 13 usb tethering to pc windows 10 and asus router both ok.
Android 14 usb tethering to pc windows 10 ok, Asus router don't see phone.
Xperia 10 IV don't present itself in the same way on usb in android 14 as
in android 12 and 13.
SatoruGojo
@TorDen Did you try another USB cable?
TorDen
Yes I have tried various usb cables, all works with android 12 and 13,
non with android 14.
The problem occurred after the phone updated to android 14, and the
phone have been factory reset several times.
SatoruGojo
@TorDen In that case you will need to contact the support team directly
TorDen
Thanks for trying to help, I think I will stay on android 13 it works.
