Hi.
Xperia 10 ii will not charge using usb charger in my car, and can't find any settings to allow.
I'm in the uk, I have tried the same cable from the house but nothing, in the car.
Solved! Go to Solution.
Oh ok, I don't see the developer main options, to get to see the toggle either, would Xperia 10 be different?
Hello @Proberts13,
you have to activate them or in this case be already connected so the menu becomes clickable.
- Nic
To get things clear.
- Your device does charge at home with a charger.
- Using the same cable your device does not charge in the car when connected to the USB port
- Other devices charge in the car using the same cable.
- In all cases ignition in the car is on. USB has power.
- You tried another cable to connect and it gave the same results.
This picture you showed.
Everything is faded.
This menu is active when you connect your device to your computer.
This menu should be active when your device is connected in your car.
Best guess so far is to have a look at the USB plug in your car or the USB connector of your device.
Hi Strampke
It was the cable all the long.
Thanks for you help
