Hello people!
Just bought the Xperia 10 plus from Sony Estore ( replacing my Xperia XZ1).
I was wondering if the style case SCBI10 fits the 10 or the 10 plus? Because when i enter to compatible cases it shows up but on other sites it is marketed for the regular Xperia 10. Bought the olixar exoshield case, but i really like this official case.
Thanks alot
Solved! Go to Solution.
Hi again @Dimitrius787 and thank you so much for the link.
That is clearly a fault and it should not be listed when only filtering to see cases for the Xperia 10 Plus, very sorry about that and luckily you asked before purchasing.
It seems to be all kind of wrong because when reading about it in the eShop, it mentions a totally different cover (Style Cover Stand SCSI10) which is different case/cover for the Xperia 10....
Thanks again for reporting this and same to you!
Hi @Dimitrius787!
The Style Cover Solid SCBI10 fits the Xperia 10 and not the Xperia 10 Plus. If you take a look at the link below, it says towards the bottom of the page "Designed for Xperia 10" but if I understand you correctly, it shows up when you filter for Xperia 10 Plus cases in the eStore? If that is correct, can you provide me with a link so I can ask them to fix this, as it should not show up for both devices.
https://www.sonymobile.com/global-en/products/accessories/durable-back-cover-scbi10/
Thank you!
Hi, Thanks for your reply & clarification
This is the link for the case : https://estore.sonymobile.com/gb/cases+protection/?p=10_plus
It shows up 2 cases, the book style & the solid style case.
@Jonas wrote:Hi @Dimitrius787!
Thank you!
Thanks alot & have a nice day!
Glad that I helped in some way! Thanks alot & keep up the good work! ππ
@Dimitrius787,
As far as I can see it has now been fixed and it's only showing the Style Cover stand.
Thanks again and have a wonderful weekend!
