Telefon posiada dwa głośniki jeden z nich nie działa....
Jaka może być przyczyna??
Lub jak sprawdzić czy jest aktywny??
The phone has two speakers one of them does not work ....
What could be the reason?
Or how to check if it is active ?? - GT
Hi @karbo, let me see if I can help out here.
I have translated your question to English as this is an International forum, please post any replies in English and it will be easier for me and other users to assist you.
That is correct, Xperia 10 plus has one earspeaker and one loudspeaker. You can find the location of the speakers on number 4 and 10 in this overview.
You can use the support app found in the device settings in order to test the functionality of the speakers. In order to do this, find and tap Settings > Support > Xperia tests > Microphone and speakers.
I hope that helped!
I had the same confusion as well. By looking at the bottom, 12.primary mic looked like a loud speaker.
