My Xperia 10 IV was upgraded yesterday to v65.1.A.4.8. After restarting I noticed some issues.
I am not sure of this is a Sony issue or an Google created issue. But what I need to know:
At the moment I can't use my phone other than for calls using a headset. I am not using it for email, messaging, maps or web etc and have resorted to my laptop for these activities. May need to consider reverting back to my XA1 if there is no resolution.
Thanks...
Hello @DangerMouse
1. have you tried to change the lockscreen clock? choose the one that is displayed in the center
settings>display>lock screen preferences>clocks
2. can't change that, but at least you won't see it if you unlock with fingerprint
3. as far as I know this happens with stock android , the options in the accessibility menu are there to help, so unless the feature is bugged there is nothing to worry about.
4. can you send a video of this happening?
Solutions:
1. you may use third party app launchers found in google play, that lets you customise how the launcher behaves
2. no you can't roll back to previous android versions as google policy,...
Hi @MarlonUk1
Many thanks for the reply. In response to you reply:
Q:Have you tried to change the lockscreen clock? choose the one that is displayed in the center
A: I have tried and quite frankly all the other clocks are ugly. I was quite happy with the current one until it got shoved to the top of the screen.
Q:2. can't change that, but at least you won't see it if you unlock with fingerprint
A: This was not a visible issue until the latest update. Not a massive problem another ugly design decision
Q:3. as far as I know this happens with stock android , the options in the accessibility menu are there to help, so unless the feature is bugged there is nothing to worry about.
A: Not sure this was stock Android until the latest update. If you have a form of motion sickness (for example I can't scroll through lots of text on my mobile) it is something to worry about. The accessibility settings should not cause more problems nor should we just have to live with it.
Q: can you send a video of this happening?
A: love to attach a video but I don't seem to have permission to.
We shouldn't have to use third party launchers to control these things. None of these problems existed when I bought the phone 6 months ago only after the recent update. Honestly this is now a very horrible phone to use.
This probably won't make you happy and won't help you resolve your issues but always be cautious
about updating as soon as updates become available.
Its always best to research any problems people experience first and then make your decision about applying the updates. I haven't upgraded our 10 IV yet.
If you want to upload videos here you firstly have to upload them to a video sharing website e.g. YouTube
and then insert the link whilst creating your post.
Sorry you're having a hard time.
I agree with @jumpsuit, It's usually the same post after every update, and we can throw a bunch of things to try, like force restart, safe mode, clearing cache and doing tests. However, it really resolves itself with time and more bug fixes, it's that annoying yet simple at the same time.
Thanks for the replies. I normally would not do the update straightaway, but it was early in the morning, logging into my work pc and the update came through - I thought "what harm could it do"
Anyway on the off chance I dropped Sony a note and the say speak to Google, and turn the animations back on...so I have a choice motion sickness or headaches. 😞
It not cheap phone (actually pre-ordered it) and now its just horrid to use. Will log a bug report with Google and see what they say.
Thanks all...
