Home Screen Shortcut
YanivYon
Visitor
I tried to add shortcuts to home screen from several apps but it's not working.
I tried to pin chart from WhatsApp and telegram
I use the default launcher
15 REPLIES 15
Jonas
Master
Hi @YanivYon, welcome to our forum!
If you want to add a shortcut for an application in your application drawer, swipe up on your home screen to access the application drawer > press and hold on the icon you want to create a shortcut for and drag it slightly upwards/downwards. You should end up with the icon on your home screen. You can now just drop it where you want, as long as there is free space on the home screen.
I hope that helps! Slightly_smiling_Face
YanivYon
Visitor
Thank You
but you didn't read my post correct
i want to add an App Specific Shortcut
one specific Chat in Whatsapp or Telegram
you do this from within the App
i tested WhatsApp, Telegram and Blackberry Hub
profile.country.NL.title
Strampke
On WhatsApp go to the group chat conversation.
Then tap the 3 dots in the upper right corner.
Tap 'more' and you will find the shortcut option you are searching for.
YanivYon
Visitor
i know where the button is
i use this function on any other android device
its not working on this phone
does anyone has the same device to test it?
Strampke
The procede as follows:
- Backup WhatsApp
- uninstall WhatsApp
- Restart device
- Install WhatsApp, login & restore
YanivYon
Visitor
what logical reason would there be to uninstall and reinstall WhatsApp if it is clearly an issue of the Launcher?
3 different Apps
now i wanted to try it with Chrome and i see that there is no button for "Add to Home Screen" in the chrome menu
so can anyone with the same device please test it?
Strampke
I don't have a Xperia 10.
What I have learned from 10 years Android phones is that you won't win by saying that it should behave like this or like so.
Experimenting and testing is the way.
So it would be perfect if you were willing to test.
If others would be willing to test as well.
If your experience affects others too and the misbehaviour remains after a reinstall of WhatsApp then this will be escalated to the developers before 8 mondaymorning (summertime).
This will either result in a communication that this is due to something whatever Slightly_frowning_Face
or that it will be repaired in a forthcoming software update.:)
YanivYon
Visitor
Despite any logical reason i have uninstalled and reinstalled WhatsApp
and what a surprise
Telegram and Chrome and Blackbarry Hub AND WhatsApp still can't add shortcuts to my Home Screen
i forgot:
Google Maps -> Location Sharing, also not possible on the Home Screen
Strampke
Thank you for trying.
I'll escalate this first thing in the morning.
