Hallo, warum gibt es in der Musikplayer App den Equalizer, den es z.B. bei dem Xperia Z5 noch gab, nicht mehr?
Solved! Go to Solution.
I don't have Xperia 1 II, but have a look at settings -> sound -> audio settings -> switch on Dolby Atmos.
There you will find preset settings plus advanced settings.
Is that what you are looking for our something else.
Let us know the results.
