Can you change volume button function on Xperia 10?
Marc14
Visitor
I have the Xperia 10 - when you press the volume up/down buttons on the side it adjusts the media volume - even when you are not playing media. To access the ring / notification volume, you then need to open the settings (which takes a few seconds) and adjust in there. I rarely want to adjust the media volume - is there a way to set the volume buttons to always be for the ring / notification, or relative to the function the phone is doing when it's pressed (ie. if it's playing media at the time, then adjust media volume, otherwise, adjust ring & notification) - or even to bring up all options in the small volume adjuster that pops up? Really annoying that it's so hard to adjust the ringer volume.
Thanks.
Tags (3)
2 REPLIES 2
Lord_viridis
I believe it cannot be changed and is part of Google's design for android.
profile.country.NL.title
Strampke
What you can set is the double push on the power button.
- nothing
- launch Google assistant
- launch the camera
You can also set the power button to end a phone call.
