Quick Tiles Menu Functions
RESUELTAS
Anders86
Visitante
On my old X Compact, the quick tiles (Bluetooth, wifi etc...) had a drop down function so you could select which WiFi network or bluetooth device you want to connect to without going into the full settings menus. Is this no longer a function on the Xperia 1?
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
RuneJ
Colaborador
Dropdown seems to be gone awhile ago/on previous models as well, but if you press and hold on the wifi-icon you will jump right into that particular menu/settings.
3 RESPUESTAS 3
RuneJ
Colaborador
Martin1
Entusiasta
Hi @Anders86, let me see if I can answer your question.
As you briefly mentioned, you are only able to toggle functions on an off using the quick settings. But as @RuneJ wrote, if you tap and hold the symbol in question, either WiFi or Bluetooth, you will be directed to that particular menu/settings for the chosen function.
I hope that answered your question! Slightly_smiling_Face
Anders86
Visitante
Thanks for the reply, I discovered this method by button punching randomly but it's a bit of a faff compared to the old drop down method, where it listed your paired Bluetooth devices. It's a minor thing but now you have to wait for the press and hold and then click on another option. Seems a bit less intuitive to me...
