Screen reslolution
dcampa
Visitor
Screen reslolution
Hi
My Xperia Z screen displays a resolution of 1080x1776 instead of 1080x1920
and 1.8 G of ram instead of 2048
where is the problem ?
I use Android Assistant for controlling this
thanks
dcampa
1 ACCEPTED SOLUTION
kalo88
Visitor
The resolution is due to the soft keys
The RAM is the same as storage, a portion is dedicated to the system (just like you never get the full 16gb of storage)
6 REPLIES 6
kalo88
Visitor
dcampa
Visitor
OK
If it is possible how  can I get 1080x1920
Thanks
profile.country.PH.title
MarlonUk1
when you watch a video fullscreen.
azzido
Enthusiast
and when playing games, why it is not full scren? the tab on the right side hould hide...
GeoffH
Enthusiast
make your complaint to the app developer - they decide how their apps should play on the device
profile.country.PL.title
azzido
Ok, I will.
As it happens to every game I was playing on Xperia Z I thought it is because of Sony modifications to Android.
Thank you.
